Zanussi Washer – Drain Issue…
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi Washer – Drain Issue…
  • #96629
    qazwsx
    Hi Everyone,
    Just looking for some advise regarding my zanussi washer dryer please if anyone can help?
    Mini 30 wash, wash completed, no spin and water left in drum. Set away cycle for drain which left some water in drum but another drain cycle and it did fully empty. Programme run for spin and all ok.
    Full 40 degree wash done. Stopped around 40 minutes to end, no errors, machine just stopped doing anything with time stuck showing how many minutes left of cycle, paused and resumed wash and it started draining and continued wash as normal. Around 20 mins to end it stopped again. Paused and resumed and each time it drained more water but not fully. It took 3 times to fully drain and continue to end of cycle.
    No errors though and washer beeped as normal at the end of the wash and spin cycle.
    Just looking for some advice to what maybe wrong with it.
    Could it be the pump not operating to full capacity or could be the board? Or are my thoughts completely out and it could be something completely different?
    Thanks for any advise and help!
    Johnny
    #464215
    qazwsx
    My apologies, it’s just a washer, integrated, not a washer dryer as I put in initial post.
    #464216
    it should be a blockage
    have you checked the filter ?
    qazwsx
    Hi Dave,
    Yes I’ve had the filter out and even removed the pump and all is clear, nothing at all stuck anywhere.
    Johnny
    #464218
    next check the outlet hose
    does it connect under the sink ? is it blocked
    is there a joint in it ( had one the other week button stuck in the joint )
    qazwsx
    Hi Dave,
    We’ve had it out from the sink end, nothing obvious there, not removed it from washer end though, the hole from the filter into the pipe looked quite small…
    Will try and get the washer end off and report back and let you know how I get on…
    Thanks so much for your help, really appreciate it!
    Johnny
    #464220
    qazwsx
    Hi Dave,
    Had pump off, nothing obvious stuck in it or the drain hose.
    I couldn’t get the drain hose off but it doesn’t appear anything is stuck in the pipe…
    Cheers
    Johnny
    #464221
    well next is to look at the pipe from the tub to the pump
    qazwsx
    Hi Dave,
    If in thinking the right thing here, do you mean from the drum itself to the pump/filter?
    Never thought of that one to be honest…
    I don’t recall seeing any pipes though?
    Cheers
    Johnny
    #464223
    its called a sump hose which also has an eco ball in the tub end that can trap all sorts of things
    comes out of the bottom of the tub and goes to the pump/filter unit (unless its one of the cheap Chinese models where the pump is mounted on the tub )
    would have checked and posted a pic but you have not said which machine you have
