Prod 91460163800
A small triac had burnt out on the original control board which caused it
not to start when `start button pressed.
Fitted new board and configured it.
Selected a prog and the prog time came into the window display ok,
pressed start – it began to fill for 3-5 secs then jumped to 3mins and
started emptying with some drum rotation. It then counted down ok to
`off`.
It does this on every prog. The 3mins seems to equate to the drain
program.
I have rechecked the config sequence code numerous times until I nearly
know it off by heart – even did it jointly with the customer.
0-1, 1-f, 2-B, 3-C, 4-B, 5-0, 6-3, 7-B, 8-B, 9-9, A-7, B-C, C-B, D-6, E-5,
F-B.
I have checked the boared plugs and wiring numerous times and all
seems ok.
I have also changed the door interlock as a precaution.
The diagnostic function seems eratic also.
Any advice that you have would be very welcome. This is my first one.
Anyone ever had a duff board.
Laurence
