zanussi washer dryer
  • #59701
    ddirect
    hi all been to a jlwd 1406 product number 914603102/00 today, (a zanussi with a john lewis badge).
    problem is the dryer. it is sensor dry, and timed dry. which ever drying setting you use it runs for about five minutes then stops, no fault code showing, checked heater and stats but dont know what resistance the thermistor is, the one located at the front of the air duct.if anyone has this information please let me know, or could the problem be,module.
    #339282
    gandh1
    Re: zanussi washer dryer
    go on to connect look up the model and in mediator will be the diagnostic manual for this. then put it thru a diagnostic test, and tell us the error code. they only tend to give out error codes voluntarily which come from user-actuated faults. i.e turning cold feed off, waste hose too low etc
    #339283
    ddirect
    cheers gandi found my tds disk will run diagnostics.
