zanussi washer dryer
  • #72746
    wilf
    zwd12270w1 914604028 01
    washes ok. dryer not working. elements, both ntc, toc, fan motor test ok. set to dry display shows time pump runs valve calls drum rotates but no fan or heat. have tried changing dryer module but still the same. any ideas?
    thanks wilf
    #385455
    Re: zanussi washer dryer
    I guess you haven’t entered diagnostics being as you didn’t add that to what you’ve already done? Also have you checked out the NTC on the bottom hose? Does the element have any insulation issues? And finally what do you mean by “valve calls”. 😕
    #385456
    wilf
    dont know how to get into diagnostics, both ntc top and bottom reading 5 to 6 k, insulation resistance over 200Mohm ,by valve calling I mean condensor valve working.
    wilf
    #385457
    wilf wrote:dont know how to get into diagnostics,
    Essential to do that on Lux stuff wilf TBH and well documented on here in the error codes thread and other places. But anyway……
    Selector switch in off position
    Press and hold Start button and nearest Option button
    Rotate selector one position clockwise
    Continue holding in the two buttons until LED’s flash then release.
    Then rotate dial to the famous Position number 10 to read the last error code/ alarm.
    ….see how you get on. 😉 🙂
