Zanussi Washer Dryer
  • #99682
    Graham G
    zanussi zwd1471s,got error E40 when switched on,replaced door catch .switched machine on with door open got error E40 again because door was open closed door then it tripped main fuse. any help welcome.
    #477392
    did it trip the RCD the one with the test button ? or one of yhe other switches (MCB’s)
    Graham G
    Yes the RCD,
    #477394
    assuming the door lock has been connected properly and you have not damaged any wires while fitting it the next components to check are
    heaters both the dryer and wash heater
    motor
    if you have not got a multi meter to test them you could disconnect them and see if it still trips
    Graham G
    Thanks Dave, will check them out.
    #477396
    sorry the pics are far too small to see
    try hosting the pics on an external site and post a public link
    dave
    #477397
    Graham G
    Hi Dave, could i email them to you,as not sure where i could host them
    #477398
    before you do that, i assume you have a multimeter
    unplug motor and set meter to about a 2M ohm scale. put one lead on the metal casing of the motor and the other one on either of the brush connection
    if you get really low reading you motor has probably failed
    also is the armature noise when you turn it smooth. what I am looking for is a clicking noise as it turns. another sign of a dead motor
    Graham G
    sensor reading on motor was 70 ohms brushes were 5 ohms armature runs smoothly
    #477400
    i need a reading to earth as that what blows RCD’s
