Zanussi Washer/Dryer dryer not heating
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi Washer/Dryer dryer not heating
  • #92782
    Twoten
    Zanussi ZWD14270W1 (914604029/00) No live to element.
    Set dryer to 40 mins, machine starts, fan runs after about 1 minute. Timer counts down very quickly and no supply to element.
    Machine does not display any errors.
    The element has a slight insulation fault of 60M’Ohms. Dryer NTC checks out OK. o obvious signs of damage to main PCB or Dryer PCB.
    I am assuming it’s one of the PCB’s and thinking most likely the Dryer PCB.
    Any suggestions would be appreciated.
    #452165
    Re: Zanussi Washer/Dryer dryer not heating
    Sounds like no connection to the bottom NTC on the condenser to me.
    #452166
    Twoten
    Thanks Martin,
    I’ll go back and check it. What resistance should I expect across the NTC?
    #452167
    Around 4 to 5 Kohms.
    #452168
    Twoten
    Thanks Martin,
    Another call for tomorrow.
    #452169
    Twoten
    Cheers Martin,
    You were spot on. The wire was broken at the NTC connector.
    Repaired and tested.
    Thanks for the help.
