Re: Zanussi Washer dryer E10 fault
whiskeyjack6058 wrote:Didnt check it Martin as I could hear water coming in on t/d.. If it was o/c it would be silent wouldn’t it?
True, but the coil can overheat and go o/c, cool then seem OK. But also do bear in mind that E10 can show during the wash cycle as well. That usually means an overfill/air pressure hose problem. So you may need to ask at what point the machine came up with the error…on wash or tumble dry?
If the answer is wash it’s either water inlet supply probs or overfill
If on tumble dry then 99.999{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time it’s the triple valve.
Fluff blockage in condenser by the way gives a E20 error. 😉
