Zanussi washer dryer E22
  • #98052
    slyp98
    hi all hope everyone is keeping well in these times, this one pnc 91460330200 , s showing E22 , i take it its the ntc in the condenser hose to the tub , im getting a reading of 4.7k ohm , the condenser and recirculating pump were completely blocked , anyone have a part no thanks Kieran
    #470709
    Hollytree_Technical
    Here is what the manual says about that code:
    E22:
    Difficulty in water fill during drying or drying condenser clogged (anti-boiling pressure switch closed on “FULL”) – Drain hose kinked; filter clogged: drying condenser clogged; drain pump faulty; pressure switches faulty; wiring; main circuit board defective; current leakage between heater and ground.
    The sensor reading looks to be about right as it says in the book 5K at 25C
    Jem
    #470710
