Re: Zanussi Washer Dryer (No Heat)
If you have power from the timer to the drier timer, and all other parts have continuity, then it is likely to be the drier timer. (1242668000). Also make sure the “Dry” button is pressed in – this will hold the timer in the drying phase and switch control of the drying to the drier timer. The drier timer switches the heaters and the thermostop on the main timer unit.
I would look at the drier timer first. 😉
Steve.
