Zanussi Washer Dryer (No Heat)
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi Washer Dryer (No Heat)
  • #52850
    subs
    ZWD1662W.
    There is no heat on the dryer. Elements, stats, thermistor all ok. I have power to elements but no neutral. Checked all connections + board as best i can. Anything else to look for before i acuse the board?
    Subs
    #313413
    martinm
    Re: Zanussi Washer Dryer (No Heat)
    check the thermistor/connections . the one thats located at bottom of condensor or possible blocked condensor
    #313414
    subs
    Whet back to this machine and checked thermister/connections and thought “nothing wrong with this”. Re-checked everything again, put it back together and its now working, so i think it may have been a bad connection on thermister.
    Subs
    #313415
    The other common fault on these is the unreliable green condenser valve coil, though that usually flashes up E10, IIRC. Worth trying if you get called back again.
    Mike.
