Zanussi Washer Dryer not drying
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi Washer Dryer not drying
  • #90010
    Icek
    I have a Zanussi Washer Dryer wdj1294 were the dryer is not working, the drum spins but there is no heat generated. Would I be correct in assuming that the condenser has a problem or there is an airflow issue. I assume that the top of the machine has to come off and the airflow ducts or the condenser is on the right hand side and probably need cleaning as lint and fluff has blocked the airflow..
    Any guidance would be appreciated
    #443261
    Re: Zanussi Washer Dryer not drying
    first you have to find out if the element is being turned on and the fan is running
