Zanussi Washer Dryer Overheating
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi Washer Dryer Overheating
  • #70270
    jonnyveeee
    Im currently working on a Zanussi Washer Dryer (zwd16270W1)
    When I select a 40deg program with ‘super quick’ selected the machine heated right the way through the program!
    Im thinking the main control board but any ideas would be appreciated!
    Cheers…
    Jon
    #377656
    Earth leak on heater? Have you meggered it?
    #377657
    jonnyveeee
    Cheers Martin!
    Ive not meggered it but will do tomorrow!
    #377658
    jonnyveeee
    Re: Zanussi Washer Dryer Overheating
    Hi martin.. I meggered the heater.. All the readings were correct & the heater is not down to earth..
    Can you think of anything else or would you suggest this is a card fault? Just to remind you.. The machine continued heating to boiling from the start to the finish of a 40deg program..
    Jon
    #377659
    Hollytree_Technical
    Does it overheat on all programs? I fit does then it suggests to me that the relay on the board has welded in the on position – give it a few sharp smacks with a screwdriver and it should release but will still need replacing.
    Jem
    #377660
    Criscold
    I agree with above but looking at wiring diagram it shows the heater is fed via the dryer relay board and not the main board
    Colin
    #377661
    jonnyveeee
    Cheers Colin & Jem.. Looks like the heater is fed off a small board with 4 relays on it (behind the main board).. Its a shame to give up with it as it is ‘as new’.. Will have a go with your suggestions & if they dont work it may be off to the scrappers as its driving me mad!
    Thanks.. Jon
    #377662
    jonnyveeee
    Just to add.. Ive just tried this machine on another 40deg wash with super quick selected & the dryer fan started running during the last 15 minutes of washing cycle for about 3 minutes..
