Zanussi Washer Dryer Timer advancing
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi Washer Dryer Timer advancing
  • #21982
    bobokines
    WJS1397W pnc 91463950300
    Hi.
    Can anyone explain why the timer might quickly advance to the end of the program on this machine. There is nothing on the TDS disk to indicate this machine does advance to the end when it discovers a fault and I have never seen a Zanussi do this before.
    It’s intermittent but did do it while I was watching.
    Set to D program. Machine fills for a couple of seconds then clicks right the way round the cycle to the end. ( The dryer fan seemed to run for several seconds in the middle of the cycle as well).
    Tried it again and run as normal.
    Third time of trying it again skipped the program.
    The motor is fine, pump is a bit noisy but functioning.
    I have checked for earth faults, brushes ok. I’m guessing that it might be the pressure system at fault and I am going back tomorrow for a further investigation..
    It’s got me stumped and any help will be much appreciated.
    Bob
    #193281
    whitevanman
    Re: Zanussi Washer Dryer Timer advancing
    A coin in the return pipe to the pump (the 1 by the stats)
    Hope this helps
    Wvm
    #193282
    bobokines
    Thanks WVM
    You were spot on. :tup: Small plastic bag stuck in behind filter.
    Thanks again.
    Bob
    #193283
    megawatt
    An interesting fault. Why would a blocked pump cause the timer to advance to the end????
    #193284
    bobokines
    This totally threw me.
    When the circulation motor starts it puts a negative pressure on the second pressure switch system that confuses the processor and sends it into a safety protection mode. ie advance to end…
    Bob
    #193285
    SimonCD
    out of interest, the timer will also advance if there is a problem with the motor tacho (loose magnet usually). i think all the models with the L shaped module do that.
    #193286
    bobokines
    That was my first thoughts with this one.
    Strange that there is nothing on the TDS disk about error detection!
    Bob
    #193287
    whitevanman
    bobokines wrote:That was my first thoughts with this one.
    Bob
    Thats why ukwhitegoods for the trade exists thanks to Dave and the moderators :worthy: , we can all use our own knowledge and experience to solve the problem :tup: .
    Glad I was able to help you out Bob, perhaps I could call on your knowledge some day like the rest of the trade members.
    Lifes a bitch but then you die, thanks to ukwhitegoods our life has been made less painfull, delivering customer satisfaction generating more custom.
