Zanussi Washer Dryer WDA 1055 – component failure
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi Washer Dryer WDA 1055 – component failure
  • #10101
    My washer dryer just died with a bang! The cycle finished but small particles of metal and what looks like concrete came out the bottom. I tilted the machine and the component is a brittle composite – red/brown in colour. Does anyone even know what the component is?
    Thanks for reading.
    #138323
    litlor
    Re: Zanussi Washer Dryer WDA 1055 – component failure
    Sounds like front counter weight has broken not a DIY job but not that expensive to have repaired
    #138324
    gr34f
    Thanks for the reply. The component did not seem to be that heavy – like your normal concrete block in a machine.
    #138325
    litlor
    When you said it went bang did it blow a fuse, does it still work, and what was the metal possible dryer duct broken up it goes around the front counter weight
    Power off when checking though 🙂
    #138326
    DAR01
    These counterweights are made up of small metal balls which has been bonded together withsome type of resin. Had a rear one break up once. Lools like coffee granules when they break up.
