Zanussi Washer Dryer WJD1257w 91460141500
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi Washer Dryer WJD1257w 91460141500
  • #57072
    OLLIE2806
    Hi guys,
    I have the above washer dryer not working – Its the dryer side – its throwing up E10 & E40 faults (i cant find them codes anywhere), I have found the valve is open circuit is likely to be the only cause?
    Ollie.
    #329714
    Re: Zanussi Washer Dryer WJD1257w 91460141500
    the codes you are looking for is any code beginning 1 ie 10 11 12
    e11 problem water fill wash
    e12 problem water fill dry
    all the customer will see is e10 unless you go into diagnostics
    so yes open circuit valve will give you e10 fault
    all e4 faults are to do with the door not locking properly
    can send you info if you let me have your email
    sorted check your email
