Zanussi Washer/ Dryer WJD1257W – Fixed?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi Washer/ Dryer WJD1257W – Fixed?
  • #26433
    Pickup
    Hi Folks,
    We have a Zanussi Washer / Dryer Model no WJD1257W. The machine was failing to drain with an error code E20. After checking filter / drain hose etc we found the impeller in the pump was not turning (locating lug on impeller broken.)
    The pump was replaced (genuine Zanussi part – impeller not available separately) however the machine now appears to need reset (display is blank and does not appear to respond to any of the buttons (except ON/OFF) on the front panel).
    Does the machine need “RESET” and if so how? I’ve checked the manual and there is no mention of a reset procedure .
    Fraser
    #210155
    Pickup
    Re: Zanussi Washer/ Dryer WJD1257W – Fixed?
    Hi Folks,
    Now fixed – “I didn’t do anything”.
    After about 45 minutes the machine started beeping and gave an Error 90 in the display (not documented in user manual). Pressed skip and then machine appeared to start to drain (although there was no water in it) and the display later returned to normal end of cycle reading —.
    I had found a topic on another site about resetting (hold Start & Skip buttons down whilst switching power on) machine so I did this and the buttons and display seemed to be re-activated.
    Machine is now 3/4 way a wash.
    I’m thinking either I disturbed something when moving the machine and it then settled down or that the machine needs to go through a specific re-initialisation programme after a part is replaced but “times out” and carries on normally if the cycle isn’t activated by an engineer – although I’m not sure how the pump could impact this as there aren’t any sensors on it?
    If anyone knows perhaps they can satisfy my curiosity?
    Regards
    Fraser
    #210156
    E90 is a communications error between the control boards. The ribbon cable connecting the two is always the prime suspect. If it is now working, leave absolutely alone 😀 .
    Pickup
    Thanks Penguin,
    Has now completed a few different washes – have absolutely no intention of touching anything! 😆
    Regards
    Fraser
