Zanussi Washer Dryer WJS1265W
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi Washer Dryer WJS1265W
  • #13038
    cantfixit
    Only the drum turns while on drying cycle. The fan, water pump, heater and water inlet do not operate. There are no error codes and the digital timer does not move from the set time.
    All other wash and spin programes operate ok.
    Had the module PCB checked out with a repair company. Reported back that the programe had locked which they reset but the card was ok. Tried out but still same. Can you please help ❓
    #152770
    Mark1
    Re: Zanussi Washer Dryer WJS1265W
    If its the electronic type machine (ie push button start) then you will need a new module which will need to be configured. If manual type timer then could be this as long as the module really is ok.
    Mark :rotfl:
    #152771
    Got to say Mark1, that doesn’t make a lot of sense…..
    CFI,
    This is an extraordinarily complex machine, with full computer control. When set, the dryer may not actually cut in for several minutes. However, you should hear the fan running fairly quickly.
    So……..
    If the machine thinks it still has water in, the dryer will not start. This may be due to pressure switch faults or blockages in the pressure system.
    The safety cut out may have been tripped. This is normally caused by blockages in the condenser system.
    The computer may, as has been suggested earlier, have lost its marbles.
    I would seriously suggest getting some help on this one. It’s a complex appliance, with numerous possibilities as to what the fault may be. Check Repairs@ or Directories for a UKW repairer in your area.
    If you wish to carry on investigating, please pull the plug first :plug: .
