zanussi washer dryer wjs1665w
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries zanussi washer dryer wjs1665w
  • #39967
    suedehead1
    hi,
    the dryer works for approx 10 minutes then stops,
    i have tried it on timed drying and sensor drying, the heater is ok the fan is turning and water is going in for the condenser, any help appreciated.
    #264317
    keithwilliams
    Re: zanussi washer dryer wjs1665w
    just a thought
    did you check to see if the condenser was blocked with fluff.
    sometimes i run machine with door open to see if there is air blowing from the conveyor. if not but fan is running it would suggest a blockage which would cause it to overheat.
    #264318
    suedehead1
    i will check that thanks.
