Zanussi Washer Dryer ZWD 1227OS
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi Washer Dryer ZWD 1227OS
  • #46897
    johnnyhoz
    Went to this 18 month old machine today, it cuts out 5 seconds after starting any program exept a drying cycle, the Start/Pause flashes continuously with no pause.
    any ideas please
    John
    #291318
    silverbroom
    Re: Zanussi Washer Dryer ZWD 1227OS
    Hi John, should come up with an error code or try this, press the start/pause button and any other option button, turn the dial one move to the right.
    Keep both buttons pressed for two/three seconds then release, this may then activate an error code.
    Had one yesterday, E31 meaning, pressure switch, wiring or PCB.
    silverbroom
    #291319
    johnnyhoz
    Thanks Silverbroom will give it a go tomorrow
    John
    #291320
    silverbroom
    That’s OK John, I am now off for a weeks holiday in France but I am sure someone else will be able to help.
    silverbroom
    #291321
    neon_3SP_glow
    This will be interesting…. I went to one ZWD16270W with excact same fault tuesday. worked fine on a dry prog, but flashes pause after a few seconds on any wash. I am going again tomo to perform the diagnostice, I wonder if we both find the same fault. gl
    In fact, the same day i saw ZWD14270W that constantly runs pump when any wash prog is selected.
    #291322
    pmb
    johnnyhoz
    ( it cuts out 5 seconds after starting any program exept a drying cycle, )
    What was the cause, I had this problem yesterday.
