Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Zanussi Washer/Dryer ZWD1680W – no lights/power
- This topic has 28 replies, 3 voices, and was last updated 12 years, 6 months ago by
nigeldclegg.
September 21, 2013 at 3:24 pm #401414
ParticipantRe: Zanussi Washer/Dryer ZWD1680W – no lights/power
Power relay is located (somewhere) on the main PCB.
September 21, 2013 at 3:28 pm #401415nigeldclegg
Thanks. I’ll get some more tools out 🙂
September 21, 2013 at 4:32 pm #401416nigeldclegg
Hi Martin,
I’ve pulled it all apart and unplugged the pcb on the front and to the side but it’s still the same. Any more suggestions?
September 21, 2013 at 5:05 pm #401417Martin
……what about the relay, have you checked that?
September 21, 2013 at 5:09 pm #401418nigeldclegg
I’m not sure what I’m looking for. I took the front panel off and disconnected the wires, took out the pcb but couldn’t see anything noticeable there. I then unplugged everything from the box inside the machine at the top right and took that out. I haven’t opened it up as it looked like there was just a pcb in there.
September 21, 2013 at 5:12 pm #401419nigeldclegg
September 21, 2013 at 5:43 pm #401420Martin
The relay is on that PCB so if you are into electronics then testing it should be your next move I would guess.
The photo you added is NOT the main PCB by the way.
September 22, 2013 at 11:43 am #401421nigeldclegg
Hi Martin,
I can see signs of overheating on the circuit board. 🙁
September 23, 2013 at 12:19 pm #401422nigeldclegg
Hi Martin,
The sticker on my pcb case reads:
Type: P451510135 F6660
Type E: 132156813
SW Ver: W2C01551I’ve found one for sale with the exact same numbers apart from it’s F60103 instead of F6660. Do you know if it will be compatible or not?
Cheers,
Nigel
September 23, 2013 at 2:30 pm #401423Martin
I very much doubt it is compatible. Which PCB are you referring to by the way, so I can be sure we are singing from the same hymn sheet here?
September 23, 2013 at 2:43 pm #401424nigeldclegg
It’s the one in a white case at the top right of the machine.
September 23, 2013 at 6:58 pm #401425captaincaveman1
I doub’t the pcb is at fault here It’s more likely detecting a fault and pausing the program . Could be the anologic pressure switch or heater at fault if the motor is defo ok but then how did you check the motor as shining a torch on it won’t tell you anything!. Taking circuit board’s apart and proding about will no doub’t cause you more problem’s call an engineer and save some cash in the long run.
October 4, 2013 at 11:32 am #401426nigeldclegg
Hi Martin,
A big thank you for all your help in narrowing down the problem. I sent the board off to this company who repaired it for £46. The washer/dryer is now like brand new.
http://www.qer.biz/lists/laundrymodels-zanussi_1.html
If you’re ever near Haworth in Yorkshire, I’ll buy you a pint.
Thanks again.
October 4, 2013 at 4:06 pm #401427Martin
nigeldclegg wrote:A big thank you for all your help in narrowing down the problem.
My pleasure, pleased to be of service.:D
