Zanussi washer dryers
  • #33981
    harley
    evening all,just thought id mention a fault ive come across a few times recently.In most cases customers complain of(the list is endless)the washer of aborting the cycle at different stages of the programme .The washer dryers in question are only a couple of years old.On both occasions the fault has been the presure pipe rubbing on the main pcb box.So before you start thinking the worst ie the pcb check to make sure the presure pipe is’nt holed or worn.
    Ihope this may help some of you,cause it nearly caught me out the first time i came across it.
    #240774
    If you want to do correct and complet diagnose, you have to get first inside on service regime, read error and afterwards look forward….
