looking at a zanussi fs1155,prod num 914791101/00,any program you select and start,the wash light comes on,the door trys to lock 3 times then end light comes on.tryed door interlock and checked pump,heater,motor,also diagnostic cycle,which lights all the lights in sequence,but when you click the timer round to perform a test function,the door clicks three times as above and end light flashes 4 times,any ideas folks,suspect the module
Had same fault on same Mod. yesterday,track blown on PCB ,block with 1yellow wire 6 red wires second red wire from right, its going to number 3 on door interlock.Dont know if PCB can be fixed.
