zanussi washer mod zwf14070w1
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries zanussi washer mod zwf14070w1
  • #63652
    fasetester
    went to repair this zanussi washing machine the woman said she put a wash on and when she came back. it was still running. it keeps pumping on every program do nothing else any help please thanks fasetester.
    #354421
    Re: zanussi washer mod zwf14070w1
    does it start pumping as soon as you turn on ?
    have got service manual for model zwf14070w
    this is model before may help
    let me have an email address
    fasetester
    yes start when you go to any programm damian799@hotmail.co.uk thank you i have pnf no 914226103(0)thank you. fasetester
    #354423
    fasetester
    when testing this machine if i disconnect the heater. or any other part would it start to operate. if the part in question was faulty by reading other post a lot of pointers go for pressure switch. or heater
    then some replace pump pressure switch heaters ect and still cant get the appliance to work.
    you can dig your self into a hole a cust wont pay for appliance that is not working.fasetester
    #354424
    fasetester
    any reply welcome if possible within next 30min going back tomorrow morning thanks fasetester.
    #354425
    BobHope
    if it just starts pumping out sa you switch it on its an earth leakage on the heater.
    Bob.
    #354426
    Criscold
    Agree could be heater, did you manage to get correct diagnostic manual for this mmachine ?
    #354427
    fasetester
    yes electrofix sent me the manual just need to figure out the flashing red and green if you disconnect the appliance parts heate ect and it was faulty would the appliance start a normal programm. you should get no reading between heater and earth. or what is the min insulation reading thanks fasetester.
    #354428
    BobHope
    there should be no earth leakage at all, under 100m ohms will cause module malfunctions. to do a quick check just diconnect the heater, but a proper insulation test is best.
    Bob.
    #354429
    you cna normally disconnect heater on zannussi’s the prog will sense no temp rise and skip heating phase. disconnect anything else and you will get a fault code
    put machine into engineering mode and get an accurate fault code and go from there
    fasetester
    thanks BOB cris dave for your help. went to machine today done a reset put it on a wash rince and spin and back to working order.
    think it was over foaming had put it throught a rince fair few times to get read of the suds thanks again fellows.fasetester.
