Re: Zanussi washer won’t stop filling
There is a level control switch which is fed from a chamber on the filter manifold – probably the air chamber is blocked which can be quite fiddly to clean and in some cases it’s easier to change the whole manifold unit which is not expensive.
If youre going to have a go yourself make sure you pull the plug first, alternatively have a look in the repairs@ section to see if there’s someone in your area as this can be a fiddly job.
