Zanussi Washing m/c leaking
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi Washing m/c leaking
  • #8372
    Make: Zanussi
    Model: FL 1030/C
    Serial: 30100664
    This machine has been working fine but it has suddenly started leaking water soon after the cycle starts.
    It appears to be coming from the drawer where you insert powder and conditioner.
    Any help appreciated.
    #128232
    Re: Zanussi Washing m/c leaking
    Francis,
    How soon after you turn it on does it leak? Straight away almost or after a couple of minutes and more? If the former, then you need to clean the soap drawer and inside the dispenser cavity. If the latter then its an expert fix job to sort out a blocked water level system. That can be sorted via our engineer help line…: –
    Repairs@
    Thanks for the advice. I think it’s pretty much straight away.
    I’m going to try cleaning the soap drawer first to see if that cures it.
    If not, I will try plan B.
    Cheers,
    Francis
