Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Zanussi washing machine bung – Urgent!
- This topic has 11 replies, 8 voices, and was last updated 15 years, 1 month ago by
lyndy.
February 25, 2011 at 12:24 pm #61311
lyndy
ParticipantGot a Zanussi washing machine – ZWF1437W, 63600146, 914522201/01
Needed to fit new drum assembly and full assembly not available so have got parts as follows:
DST1321570408 Outer tub – back half
DST1320074303 Inner drum
ZAN1240159002 Drum/backplate gasket
DST1321446203 Door seal
DST50276843005 Outer tub – front half
DST1321020206 Wash elementProblem is the front half of the outer drum has a hole where the breather pipe from the soap drawer would normally be but this model doesn’t have this pipe – breathes to the door seal instead.
Does anyone know of a bung that fits this hole?
The recommended alternative for the front half of the outer tub we are using is the counterweight kit, DST50286079004, but this part in not available so we need to use what we have.
This is urgent so any help would be appreciated.
Thanks.
February 25, 2011 at 12:28 pm #345631rogue_element
ParticipantRe: Zanussi washing machine bung – Urgent!
Sorry mate i would not seal the hole
February 25, 2011 at 12:43 pm #345632lyndy
Its an open hole – water will come through when the machine is in use. A bung is needed.
February 25, 2011 at 6:36 pm #345633Turbo
Better to scrap the machine than lash it up which may cause a flood and damage your reputation.
If there is no official blanking bung listed by Zanussi then it is not worth the risk.Graham
February 26, 2011 at 6:00 pm #345634cab
no offical bung, wrong front tub!!!
February 27, 2011 at 1:39 am #345635gandh1
and can we ask why arent you using old front half of tub if its a split tub design???
February 27, 2011 at 9:13 pm #345636bigchrisoioi
check the pnc..i think u have the wrong elc code!
February 27, 2011 at 9:15 pm #345637helo_75
Participantput the correct breather hose in it and bung the other hole up? the only problem you will have is the fact that it needs to breathe somewhere so the water level will be correct
February 28, 2011 at 9:46 am #345638funkyboogy
while we are on the zanussi bung subject , i just done rear tub etc
but didnt receive the little bag with the bungs , now im needn bung and disc that fits in thermostat hole in rear tub ..there was nothing in the box .. appliance all ready to go apart from missing bung
anyone got a part no . used to get a little bag with all things required ..
cheers ally
February 28, 2011 at 10:48 am #345639lyndy
ParticipantIts a RC approved job – the front tub we have is listed on CDSL as a spare for this model.
We’ve managed to get the machine written off now.
Thanks guys
February 28, 2011 at 12:29 pm #345640funkyboogy
i wouldnt rely on what r/c system says fits , you best getting a tds disk … we had a mare with zanussi parts on r/c system ..
ally
February 28, 2011 at 3:05 pm #345641lyndy
ParticipantYeah I know – we use TDS too but difficult to order some bits via RC as you know.
