Re: Zanussi Washing Machine Fault
Could well be a blocked drain filter/drain spigot where the drain hose goes on under the sink or worst case the pump’s failing when it gets hot which would require replacing.The other thing that could cause it is the pressure vessel which feeds the pressure switch may be partially blocked causing the pressure switch not to release. If the switch still registers water in the tub the PCB will abort full spin.
