Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Zanussi Washing Machine FJS1397W
- This topic has 5 replies, 5 voices, and was last updated 20 years, 1 month ago by
neptune.
March 3, 2006 at 6:47 pm #16080
neptune
ParticipantI am struggling with this machine . The reported fault was , machine fills on a wash . It then does nothing , and the customer, an ex telecomms technician, obtained and fitted a new timer . the fault remains. Motor and pump work on a spin prog, Heater testsOK. I have sent the module to QER for test/repair . Comments/advice welcome please.
March 3, 2006 at 7:02 pm #167462Penguin45
ParticipantRe: Zanussi Washing Machine FJS1397W
Funny blighters these – have had timer, module or both together quite regularly. EMW product very good though.
March 3, 2006 at 7:06 pm #167463aqualectric
The solder joints for the motor relays on these boards burn around the pins ie no wash motor but may spin. You did not say if the jetsystem recirc. pump was running at all during the test.(but that may just be the pump jammed or failed, no particular probs if there is power to it) There will be silence without the motor turning as the board only impulses the timer motor occasinally making the timer seem like it’s dead. PCB board repair should solve it.
Hope this helps!!!March 3, 2006 at 7:31 pm #167464neptune
Thanks for the replies so far . There are no visible dry joints on module . This machine has 2 pressure switches . The rear one seems to be the one used on wash . If I remove its pressure tube and fit a spare tube to the swich and blow it to the second level, the jetstream pump switches in .
March 3, 2006 at 7:40 pm #167465wilf
you have checked tacho I hope
wilf
March 4, 2006 at 9:54 am #167466farmboy
One air tube feeds of the top of the sump hose, the other feeds from the filter housing – check the condition of both air tubes, check the air chamber on the top of the filter housing. Also check the sump hose for blockages.
When it fills up on a wash it needs a signal from both pressure switches, if it gets a signal from only one it will normally fill to the higher water level then stop dead.
