Zanussi washing machine model zwg1120m E62 error code
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi washing machine model zwg1120m E62 error code
  • #76984
    Carloose
    Zanussi washing machine model zwg1120m prod. no. 914579816 seriel no 13859945 E62 error code when selecting any cycle machine sets off full spin then throws this code up and stops any ideas thanks Carl.
    #400322
    Re: Zanussi washing machine model zwg1120m E62 error code
    Moved to correct forum.
    E62 is supposed to signify overheating during wash cycle.
    Not got my main PC on ATM, is it a washer dryer?
    Going right into spin can be a motor tacho fault or even a main PCB problem.
    #400323
    Carloose
    Its just a washing machine, sounds like a major problem 🙁
    #400324
    If it does try to go into fast, uncontrolled spin then it may be a loose tacho magnet. They do come unscrewed occasionally on these.
    #400325
    Carloose
    Just had a engineer out to look at it motor ok looks like board has gone down 🙁
    #400326
    Seamy
    It needs a PCB replaced, the motor control triac has gone on the P.C.B, done dozens of them, P.C.B required, is E62 on these not normally a motor or tacho problem.
