Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Zanussi Washing Machine – replaced pump but still get E20 and doesn’t drain properly
- This topic has 7 replies, 2 voices, and was last updated 5 years ago by
acr.
March 25, 2021 at 7:37 pm #99342
acr
ParticipantHi – I’ve got a Zanussi ZW171201WA which has stopped draining properly and displays error code E20. I’ve cleaned the filter, checked the hose and replaced the pump and its still doing it 🙁
Any ideas?
ThanksMarch 25, 2021 at 10:56 pm #475923electrofix
Moderatorif you fill it with water and then select drain how long does it take to drain it ?
March 26, 2021 at 8:32 am #475924acr
Participantelectrofix wrote:if you fill it with water and then select drain how long does it take to drain it ?
Thanks for the reply Dave – if i just switch it to the drain programme it doesn’t finish draining – it starts and does about half and then freezes but doesn’t give an error code. I can get it to empty by repeatedly restarting the drain programme. If I try a normal programme it seems to work fine but then can’t spin because of the water so then gives an E20 error code
March 26, 2021 at 12:04 pm #475925electrofix
Moderatorfill with water does it
A drain quickly so you can see the water going down and then reports E20
B drains very slowly and reports E20 after which there is still water in the drum
March 26, 2021 at 1:44 pm #475926acr
Participantelectrofix wrote:fill with water does it
B – very slow
March 26, 2021 at 2:44 pm #475927electrofix
Moderatorin that case you have a blockage you just have to find it
i would take the sump hose off the drum first
I assume you have tried taking the outlet hose off the sink or where ever its connected and tried draining into a bucket. Just to eliminate blocked sinks etc
March 26, 2021 at 2:46 pm #475928acr
Participantelectrofix wrote:in that case you have a blockage you just have to find it
OK thanks, yep i’ve got the outlet hose draining in to a bucket – i’m not sure where the sump hose is but I’ll google it 🙂
Thanks for your helpMarch 26, 2021 at 3:11 pm #475929electrofix
Moderatorsump hose is the large hose that leaves the bottom of the drum and goes to the filter/pump
