I’ve got a Zanussi IZ141 w/m which is stopping in mid-cycle, about 3 or 4 mins into the cycle. It fills with water then stops with the pause / stop light flashing.
I was suggested that the recirculation pump could be creamed, so I’ve replaced that, but it hasn’t fixed the problem.
I’m now thinking that it could be the heating element as the water doesn’t seem to be warm when it’s filling as mentioned above.
Too early in the cycle for the heater to be switched in. Try the motor brushes as the machine will fill first, then run the wash motor. PCB module may not find the motor due to open circuit. 😉
Power off before ANY inspection. Be safe!! :plug:
