Went to a Zanussi ZWF1240W Prod. code 914517515/00 . Start prog. door locks and pumps then wash light goes out and machine ends program, E30 came up . Error code not listed and to make matters worse it works ok sometimes. Tried new valve as it does not start to fill before it ends prog. but to no avail. Is this timer module fault ?
Thanks for your replies .I have called back and checked motor and element again and they seem ok . I removed pressure chamber and cleaned the sump hose and chamber reassembled and it has worked touch wood .Will let you know if it keeps working .
