ZANUSSI WASHING MACHINE ZWF1632W
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries ZANUSSI WASHING MACHINE ZWF1632W
  • #68661
    winker
    customer says this machine stops on cycle.It does.The prewash, mainwash light and spin light is on and the start pause light is flashing continuously.The drum has a low fill of water.I am tempted to suggest this happens in the rinse section.I have no
    fault code charts for this model so a little stuck.Any ideas spring to mind or info greatfully received
    steve
    #372206
    tj5793
    Does the start pause button flash in red then green? If so this is the fault code. Send me your email address I will send you a fault code manual which covers most models
    #372207
    winker
    Re: ZANUSSI WASHING MACHINE ZWF1632W
    no only flashes green as though it is on pause.Customer said it stayed like that for half an hour and then started again on its own.I have pm’d you with email.
    #372208
    winker wrote:Customer said it stayed like that for half an hour and then started again on its own.
    Dodgy interlock or connector plug to it?
    Dicky plugtop or socket?
    #372209
    clockworkone
    poor water pressure or blocked inlet valve.
