Zanussi WD1627OW
  • #46735
    rocker
    Customer tells me machine takes in water, but after about 1 min it stops. start/pause light flashing..if timer is moved to drain/ spin, will drain somtimes but not always intermittent, but if left overnight, it can be reset but fault continues, sound like a possible board fault!! as anyone had this fault or can advise please. cheers John.
    #290692
    timdowning
    Re: Zanussi WD1627OW
    Check all the obvious things first.
    Brushes, heater, valves, pressure and drainage system.
    Module unlikely.
    #290693
    chris211
    check for fault codes in diagnostic if it showing ed4 it will be dryer element they are very prone to failing and bring up sorts of faults
