Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Zanussi WDA1255W overflowing
- This topic has 6 replies, 3 voices, and was last updated 16 years, 2 months ago by
shishman.
January 25, 2010 at 2:29 pm #51954
shishman
ParticipantWe have a Zanussi WDA1255W washer dryer that overflows through the soap tray.
It is ok on a wash cycle but when the rinse cycle starts the cold water will not shut off and the machine overflows.
I have checked the small hose from the pressure sensor and it seems clear so am now very puzzled.
Thanks in advance.
January 29, 2010 at 12:30 pm #310102shishman
ParticipantRe: Zanussi WDA1255W overflowing
Help!!
Anybody with any ideas what is wrong with the machine please.
My girlfriend getting a bit concerned.
Thanks again.
January 29, 2010 at 12:47 pm #310103Phidom
A bit more information is required, hence the lack of replies. Is the drum filling right to the top then water overflows from the drawer or does this happen without the drum overfilling? Have you washed out the soap drawer including the syphon bits of the fabric conditioner compartment?
January 29, 2010 at 1:16 pm #310104shishman
Thanks for the reply.
The water is filling the drum and then flowing out of the soap drawer. I have washed the drawer out as well.
January 29, 2010 at 4:19 pm #310105Phidom
In that case you will probably find the pressure vessel is blocked. I find it best to remove the whole filter housing and wash it out at the sink. The filter housing is clipped to the base of the machine, possibly with a single screw in addition to the clips.
January 31, 2010 at 3:04 pm #310106shishman
I have removed and cleaned out the white “tank” in the bottom of the washer. This wasn’t blocked in any way. The hose from the pressure sensor leads to a plastic assembly on the side of the drum which I believe is the pressure vessel. I have already blown through the pipe but if this is blocked it looks like it cannot be removed to be cleaned. So, what would be the best way to clean this part.
Thanks.
January 31, 2010 at 5:42 pm #310107Penguin45
Split the casing in half for access. Air bell is retained by a spring clip and one screw.
