Zanussi WDJ1294 (91463900/00)
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi WDJ1294 (91463900/00)
  • #62801
    rocker
    I need to removed the lid, but it has security screws fitted.
    They are trox screws with centre pin..can anyone tell me the
    Tork size number I need to remove these. please. john
    #351368
    Re: Zanussi WDJ1294 (91463900/00)
    rocker wrote:can anyone tell me the
    I’d have given money to think you long since had youself a set in your toolkit. 😕
    The size you need for this job is a T20H and you can get a full set from THIS WELL KNOWN STORE 😉
    #351369
    rocker
    Martin, yes you are correct I own two sets but over the years have managed to loose the odd ones, this size being one of them, but will splash out and replace.
    thanks for your reply. John
    #351370
    I have come across this problem before too. They can be a bit tight and break a cheap torx bit. You can usually loosen them by centre punching the screwhead at an angle to start it on its anticlockwise way. Or if things get really desperate, saw through the plastic lugs. Replace with a normal 8mm head screw and a large washer.
    Mike.
    #351371
    leavemetogetonwithit wrote:Or if things get really desperate
    Blimey, that’s a bit extreme Mike, we’re only talking a couple of lid screws here after all.
    I’m sure Rocker won’t be reaching for his hacksaw any time soon!
    #351372
    Nice pic!
    Mike.
    #351373
    leavemetogetonwithit wrote:Nice pic!
    I was up all night drawing that, so ta muchly for the compliment. 😛
    #351374
    Blimey, that’s a bit extreme Martin. We’re only talking two screws here after all. 😆
    Mike.
