Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Zanussi wdj1294 not spinning
- This topic has 8 replies, 2 voices, and was last updated 6 years, 6 months ago by
Icek.
September 20, 2019 at 3:11 pm #96423
Icek
ParticipantMy Zanussi Washer dryer was on a cycle spin and there was a loud bang that tripped the MCB. There was also a burning smell and now the machine switches on, but the drum will not spin. I am thinking its the motor and or capacitor. Washing Machine engineer said that it was beyond repair and the parts were not available. Looking for a second opinion as the machine is nearly 25 years old and has served its time well.
September 20, 2019 at 8:46 pm #463286electrofix
Moderatordid the engineer tell you what parts have gone ?
would need the pnc number to check part availability
there is also a complete machine on ebay in Thatcham which has a slow fill problem which will be a valve but its probably miles away
September 21, 2019 at 9:24 pm #463287Icek
ParticipantHi Dave
NO part number, Engineer seemed to think it was a lost cause and yes I checked Ebay and there is a machine there, however, its about 200 miles away from me.
Does it sound like it could be the capacitor, where about is it in the machine, so I can open it and get the capacitor out to replace it.September 21, 2019 at 9:29 pm #463288electrofix
Moderatordid it blow fuses or the rcd trip?
September 22, 2019 at 9:58 am #463289Icek
ParticipantHi Dave
It tripped the RCD, there was a loud pop and a burning smell from the washer. Now it powers up and when you spin the programming dial it sounds as though its working but the drum does not spin.
Regards
IceKSeptember 22, 2019 at 10:16 am #463290electrofix
Moderatordoes sound like a motor problem. the worry is how bad it has gone. has it just blown the motor or has it blown some of the electronics as well
if you let me have the pnc number which should be 9 number followed by 2 more
I will see if the motor is still available and cost it
September 22, 2019 at 3:51 pm #463291Icek
ParticipantHI Dave
PN is 914639003 Type P 6297284 Mod WDJ 1294/A
Regards
September 22, 2019 at 4:29 pm #463292electrofix
Moderatornew motor
https://shop.ukwhitegoods.co.uk/1325287017-washing-machine-motornot really a viable option
used motor
looks highly likely its the same motor
there is a chance something else has blown but to find out you would have to strip the machine and look at the motor control board
September 23, 2019 at 1:21 pm #463293Icek
ParticipantThanks for your support Dave, I ended up getting a new washer incase any further faults developed after Motor replacement
