Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Zanussi WDS 1183 W Door handle replacement
- This topic has 6 replies, 3 voices, and was last updated 19 years, 4 months ago by
simonbell.
December 6, 2006 at 7:43 pm #23166
simonbell
ParticipantHi
Can anyone tell me how to replace the door handle. I presume I need to remove the outer door trim, does this come off easily or is it likely to break.
With it removed will I be able to remove the door handle?Thanks
Simon
December 7, 2006 at 1:12 am #197191Penguin45
ParticipantRe: Zanussi WDS 1183 W Door handle replacement
Assuming that you’ve got the door open, remove the door from the machine. Most have a couple of screws holding the outer panel to the inner – remove them and prise the outer panel off. Two screws then retain the handle/catch assembly and it’s all pretty obvious from there. Make sure you get the sprng back on the right way round…….
Penguin45.December 8, 2006 at 1:19 pm #197192simonbell
Sorry, should have said the door is still locked………any tips on getting it open…….
Simon
December 9, 2006 at 1:03 am #197193Penguin45
Ah – much more fun. If you are sure that the door handle is actually broken, rip off the remains. This should just about allow access to the door hook, which you can prise back with a thin screwdriver. Theoretically, you can get it from the outside edge of the door, but you will scratch the paint. If it really won’t release, you may have to get it from the inside. Power off if you have go down that route.
Good luck,
Penguin45.December 9, 2006 at 6:40 pm #197194simonbell
A small piece had broken off the handle behind the latch so in the end I had to remove the handle piece by piece using a dremel. Once enough had been removed I was able to get a screwdriver at the latch and open the door. I`ve now removed the trim panel on front so that I can get at the latch screws.
I`ve ordered the part online and in the meaintime we can use the machine by opening it with the screwdriver. Thanks for the advice, considerably cheaper than getting someone to fix it
Simon Bell
December 22, 2006 at 5:36 pm #197195dariop
How did you manage to get the door to open? I have the exact same problem, the door opening handle broke off. The door is closed and I cannot see what to lever to get the door to open. There are just two broken sections of plastic, and a spring between them.
Any help appreciated.
December 23, 2006 at 12:40 am #197196Penguin45
Post #4.
