Zanussi WDS1183
  • #37934
    Any one have any fault codes for this model please.
    E20 showing on dry cycle
    Simon
    #257176
    Simon46
    Re: Zanussi WDS1183
    pump intermittent(overheating on toc). not draining.
    S.
    #257177
    Re: Zanussi WDS1183
    Known Error Codes – p3.
    Re: Zanussi WDS1183
    thansk for help, i saw the error code on there, but this one has no problem on the was cycle only on the dry, and even if you only put it on the dry it comes up after a few seconds
    #257179
    neilsukwg
    Re: Zanussi WDS1183
    usually a blockage even if machine works ok on normal discharge, a slight blockage will send dry cycle up the wall.
    Check condenser for blockage as well.
