zanussi wdt 1085 steaming and leaking when drying
Home Forums Public Support Forums Help And Support Washing Machine Help Forum zanussi wdt 1085 steaming and leaking when drying
  • #16250
    brownatron10
    hiya wondered if anyone can help?
    i got a zanusii washer dryer wdt 1085 type p6296154 serial number 55000574 and when its on the drying cycle i have to open the powder drawer to release the steam or i get it leaking out in other places.any ideas greatly appreciated
    phil
    #168966
    Goatboy
    Re: zanussi wdt 1085 steaming and leaking when drying
    Hmmm!, That could be a blocked condensor unit?
    It dries the clothes, does it?
    Unless you have the patience of Noah, use Repairs@, or if you wanna try it yourself, unplug the machine first.
    #168967
    brownatron10
    its drying fine just got gurgling and steam,what does the condensor look like and is it a big job to unblock?
    #168968
    Goatboy
    brownatron10 wrote:…and is it a big job to unblock?
    Yup! 😕
    If you use the search facility, there’s lots of posts about this.
    Note: It might not be your condensing unit!
    #168969
    brownatron10
    cant seem to find owt about condensors might just call some one out if its a big job
    thanks pal
    #168970
    Goatboy
    Goatboy wrote:…use Repairs@, or if you wanna try it yourself, unplug the machine first.
    The condensing unit is the large plastic (see-thoughish) tub thing on the back of the main tub. I say see-throughish, because it should be fluffed up!
    To acess it the washer’s cabinet has to be split, which is top off, then the whole back half of the machine comes off. If you can’t do that, I’d call an engineer then! 😉
    HTH
    #168971
    brownatron10
    cheers pal ill give it a go an let ya know how i get on
    #168972
    DDSDDS
    I have had the same fault if the condensor unit comes away form the top mounting if you take the lid off you will see a tube out of place
