Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › zanussi with hole in rear tub with pics
- This topic has 10 replies, 7 voices, and was last updated 15 years, 2 months ago by
shaun67.
January 23, 2011 at 9:31 pm #60444
shaun67
ParticipantWent to look at this ZanussiWJS1665W yesterday ..Complaint of washer/dryer leaking 😯 Woman wants it repairing ..Checked motor to make sure it was not frazzled and was fine when tested with meggar.. Board looks ok ,circulation pump is fine etc …Heater tested with meggar 9.2m so gonna replace .Stats and NTCs were all ok ..Surprised this has not blown the board .Bearings are all sound apart from the hole lol.Told woman i can not gaurantee this but will have ago.
Is that “quick steel plastic repair “any good for such as this or does anyone recommend anything better .Woman does not want me to replace rear tub and knows that this is not the best option but willing to go ahead .I don’t mind a little challenge lol.
Just like to say that the dryer condenser was absolutely blocked ,cannot understand why people let things like this happen.Shaun
P.s sorry about size of pics 😆
[/img]January 23, 2011 at 9:59 pm #342172A1TEC
ParticipantRe: zanussi with hole in rear tub with pics
You would have to like a challenge to take that one on. 😆
Would be interested to see it after the repair. 😉January 23, 2011 at 10:03 pm #342173shaun67
A1TEC wrote:You would have to like a challenge to take that one on. 😆
Would be interested to see it after the repair. 😉Well i’m gonna have a go 😉 woman knows it’s not looking good but worth a try as she ain’t holding me responsible if you know what i mean … i have explained and made it quite clear 8) Just need to get the right stuff to seal it..Will try and get pics up once done 😉
January 23, 2011 at 10:07 pm #342174iadom
ModeratorRe: zanussi with hole in rear tub with pics
Looking to the left of the hole it looks like there is further heat damage on the drum.
My guess is that the heater has been on with no water in the drum.
Unless you isolate the reason for this I wouldn’t bother fixing the hole. 😥
It might be better to wait until tomorrow when one or two of the Zanussi experts have had a look. 😉
January 23, 2011 at 10:08 pm #342175rolf
Way to risky. Just imagine if your putty or what ever comes out. Big time flood.
I bet she would hold responsible then.January 23, 2011 at 10:14 pm #342176iadom
rolf wrote:Way to risky. Just imagine if your putty or what ever comes out. Big time flood.
Or even worse, a conflagration. 😯
January 23, 2011 at 10:26 pm #342177shaun67
iadom wrote:Looking to the left of the hole it looks like there is further heat damage on the drum.
Jim.Yep would agree with heater coming on as there was quite a bit of blockage in the system , it’s only a little hole in the tub 😀
Only joking about the hole been little and yes i seen the bit near to the left as well …
Gonna come clean fellas ,i already have a rear tub comin from the recycling centre near me …got to know one of the lads there and got this sorted ..I am not that stupid to fix a hole like this when heater damaged it ..Sorry for my weird sense of humour ( thought of super glue ,that ones for the guys who know me 😉 )Just thought i’d put this up to show what damage can happen when heater comes on..I put it in wrong place but did not know how to put it in the ” a picture says a thousand words ” thread once i had posted it here 😳
Ps if anyone can put it in the appropriate thread it would be appreciated 😀
January 24, 2011 at 12:43 am #342178leavemetogetonwithit
Not easy, no. Is that the heater element visible through the hole? If so, does the element extend to where the thermistor is? If it does, then that grommet has been able to survive there. Maybe you could get a similar grommet and stat off the scrapper, cut a hole of the right size with a hole cutter, with element out of the way and make sure you get a nice fit. Have to make sure the other melted areas haven’t thinned the plastic or distorted the drum.
Alternatively, someone in a previous thread said he gets good results with a portasol gas powered soldering iron. You could have a go with that. I’m intending to get one for myself.
I know you’ve already arranged another solution but there might come a time when you’ll really want to fix a drum this way.
BTW, don’t forget to figure out why it happened before you fit the new tub. You don’t want to find out after that you also need a new board.
Mike.January 24, 2011 at 9:13 am #342179Martin
leavemetogetonwithit wrote:BTW, don’t forget to figure out why it happened before you fit the new tub.
iadom wrote:Unless you isolate the reason for this I wouldn’t bother fixing the hole. 😥
Pressure Switch (anti-boil) failure? Crudded up air hose maybe?
These Lux heaters don’t have integral microtemps fitted so be sure to advise your customer to install a smoke detector above the washing machine, just to be on the safe side.:wink:
As for the hole? Err?….oh just stick a cork in it!:innocent:
January 24, 2011 at 9:49 am #342180leavemetogetonwithit
Martin wrote:
These Lux heaters don’t have integral microtemps fitted😯 😯
What?? Is that some kind of cost cutting measure?
Mike.January 25, 2011 at 8:04 pm #342181gandh1
weve had that before, customer binned it when we tallied up the cost. and bought another zanussi – a zwf12070w1 :rolls:
