Zanussi WJD 1257W (91460141500) Replacement Brushes
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi WJD 1257W (91460141500) Replacement Brushes
  • #41229
    Kelvin
    I need to change the brushes on a Zanussi WJD 1257W (91460141500)
    Can you please confirm the type, as the ones on you show have a different location for the terminals.
    Also it looks like they are fixed in by 5.5mm bolts is this correct
    Many thanks
    Kelvin
    #269188
    Re: Zanussi WJD 1257W (91460141500) Replacement Brushes
    Your machine is fitted with a SOLE motor, the replacement brushes can be found HERE.
    I assume from your comment that you have the red carbon brush holders with the tab halfway along the side of the casing? The ones above are a direct replacement.
    The screw heads are indeed 5.5mm.
    Power off if you’re tackling this yourself.
