zanussi wjd 1667
  • #52595
    Kez
    been out to this today when you switch it on the lights on the facia flash randomly all over the place and are unable to select programme any ideas gratefully received thanks
    #312376
    TheSpinDoctor
    Re: zanussi wjd 1667
    Hi.
    My first thing to check would be the blue interface cable between the main & user board. Usually if you take the plug on & off several times at each end this cleans the contacts as they become oxidised.
    #312377
    Sounds like it might have been accidentally put into some sort of diagnostics mode.
    Mike.
    #312378
    TheSpinDoctor
    That is a good point, Mike.
    If so, just turn it off, then on, then off, then on again. That should ensure you exit diagnostic fully.
