Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Zanussi WJD1257 drain pump
- This topic has 5 replies, 3 voices, and was last updated 20 years, 8 months ago by
admin.
August 11, 2005 at 10:29 am #11257
KeymasterMy 2 year old Zanussu washer/dryer has an intermittent problem where it is not draining at various part of the cycle and giving Error code E20.
I’ve checked/cleaned the drain filter but the problem is still there and getting worse. I supect the drain pump is jamming since all I can hear while the machine is not draining is a slight hum, no pump sound.
Does anyone know if it’s not too difficult to remove/clean or to replace the drain pump? I had a quick look from the bottom of the machine and can’t really see how to get to it, perhaps I’m missing some hidden access panel/way in? Of cause the next question will then be where can I get a pump from 🙂
Paul
August 11, 2005 at 11:37 am #144515Dave_Conway
ParticipantRe: Zanussi WJD1257 drain pump
It certainly sounds like the drain pump.
There are various versions of this model though, can you check the rating plate and post up the number beggining 914???? please, I can source the pump then for you.
Front right corner normally (pump position) 🙂
August 11, 2005 at 2:54 pm #144516admin
KeymasterRe: Zanussi WJD1257 drain pump
From the rating plate:-
91460140600
Type: P6347670I put the machine on its back and think I could see the drain pump through the bottom of the machine. Is there any other access to the pump other than through the bottom? It looked hard to gain much access to it, and I can’t see any other obvious access covers.
Paul
August 11, 2005 at 3:53 pm #144517Dave_Conway
There you go, pump in the shop for you 😀
http://www.ukwhitegoods.co.uk/modules.p … cts_id=394
You can do it from underneath, you can also split the cabinet, please don’t be tempted to tip the machine upside-down though 😉
August 11, 2005 at 7:27 pm #144518litlor
Easy job pull the plug out tip machine back enough to get your head under there are 3 Philips screws attaching the pump to its housing undo and then fit new pump 5 min job
__________________
John
August 12, 2005 at 10:14 am #144519admin
Thanks for the help.
I’ll trying removing the pump later and then order up a new one.Paul
