Zanussi WJD1257 no heat
  • #6621
    machineman
    hi everyone , mc blew a fuse now no heat checked heater all ok configured pcb still no heat any ideas, could it be something other than the board.m
    #118699
    machineman
    Re: zan wjd 1257 no heat
    anybody there .m
    #118700
    machineman wrote:anybody there .m
    Sorry can’t help on this one 🙁 But pm Alex as he is a bit of an expert I believe :tup:
    Dave_Conway
    Re: Zanussi WJD1257 no heat
    Are you absolutely sure the heater is OK ?
    #118702
    machineman
    yeah took back off filled m/c no neut to htr tested cont and earth leakage all ok comes up as code e55
    #118703
    lokring
    well! acording to the diagnostics e55 is an open circuit motor/ciruit, thats thrown a spanner in then!
    #118704
    machineman
    sorry looking at wrong table. e66 heater ele relay fault m
    #118705
    lokring
    ahh! give the thick grey wires around the presure switch a tug could be a fault in that area!
    #118706
    SL
    🙄 Check the NTC has not been damaged or has burnt. This will stop the heater relay from switching on, also check that the safety level part of the pressure system is closed as this provides the neutral to the heater.
