Zanussi WJD1257W Dryer not working
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi WJD1257W Dryer not working
  • #57010
    myfil
    We have a customer with a Zanussi WJD1257W washer/dryer with the dryer not drying – no voltage to the elements (which are OK). Fan works, water valve works. Continuity on both the side stats including the resettable one.
    I know there are two NTCs on this machine – one at the front top of the dryer manifold (which has a resistance of 5.22 KOhm) and a probe type on the side rubber hose (not tested, as I did not spot it on site).
    Can anyone tell me the correct cold resistance of these two? Which one usually fails?
    Also, what are the chances of it being a PCB fault (burned relay contacts perhaps) before I go buy the NTCs??
    Thanks guys
    #329543
    Turbo
    Re: Zanussi WJD1257W Dryer not working
    Broken wire on lower thermistor terminal maybe, it is very common.
    Graham
    #329544
    allan73
    Ditto, had a few of these with broken wires to lower ntc.
