zanussi wjd1257w filling with water on drying cycle
Home Forums Public Support Forums Help And Support Washing Machine Help Forum zanussi wjd1257w filling with water on drying cycle
  • #12110
    lithanwif
    My zanussi is driving me mad. The wash cycle is completely fine. Couldn’t ask for more. Clothes are spun well to almost dry. Then I put it on to dry, and I end up with hot wet clothes. I have put the drain into my sink to check and a large amount of water is coming out, but once the cycle has been on, If I put my hand into the dryer, there is a pool of water at the bottom of the drum and my clothes are all soaked. Had a washing machine repair man have a look, but he didn’t do dryers.
    Help
    Lithanwif
    #147930
    Re: zanussi wjd1257w filling with water on drying cycle
    Your washer dryer is suffering from a blocked condenser unit I should imagine. Also you need to check the drain filter regularly as they get blocked and restrict the drain outlet flow.
    The machine is complex in nature and taking off panels and lids is not a recommended DIY exercise. Therefore I strongly advise contacting a local independent engineer (although not the last one apparently 🙄 ).
    We may have one listed via this link: Repairs@ to get it sorted. 😀
    #147931
    lithanwif
    thanks
    I do regularly check the drain filter and it seems to be clear, although it has been clear for months now, which concerns me too.
    is there any way I can check the condenser unit?
    what does it look like?
    #147932
    No, not without moving panels 🙁 (See my previous comment)
    #147933
    lithanwif
    Could you give me a ballpark figure on the cost to get an engineer to unblock it?
    #147934
    Not a lot considering the value of the machine and its likely lifespan….But do please enquire locally as labour rates vary so very much. (Hit the link I gave for more info)
    #147935
    lithanwif
    got a guy coming around in the morning, thanks for the link
    #147936
    chasethemeridian
    Hi.. I have exactly the same model and symptoms. What did the engineer do, and what did it end up costing ?
    Regards
    chase
    #147937
    He hasn’t come back to let us know. He’s got an email on his Profile, drop him a line and let us know perhaps?
    lithanwif
    the engineer tested lots of things and told us it was one of the motherboards (the side one).He gave us a figure of £130 for the board, plus labour. But my wash cycle was still working, so I spent £20 on adtrader and bought a tumble dryer which works way better anyway. I can get a wash done in the washer and it will dry in 45 mins in the tumble dryer.
    Now I just have to find somewhere to put the ruddy thing
    #147939
    Is the correct answer! Far more efficient. IME, people only ever buy one washer dryer due to the inefficiency of the dryer set-up.
    £130 odd is about the right price for the board BTW, so he wasn’t winding you up.
