Hi all
got the following fault with a zanussi wjd1257w 914601415/00 that i hope someone can help me with.
originally when an auto dry cycle was selected the machine would show the proper drying time on the display but would only run for approximately 10 minutes before the cycle was finnished and the machine didn’t produce any heat. however it would dry ok on a manually selected cycle, but is now giving the same fault as described above on the manual cycle, i also noticed that when the timer starts to count down it is counting down in 18 second intervals rather than 60 second intervals, could this be a pcb configuration problem/fault and if so does anyone have the configuration info for this machine. i have checked all the wiring, filters, condenser etc etc just to be sure. any help would be greatly appreciated.
Brian
