Zanussi WJD1257W. Sticks at 26 mins.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi WJD1257W. Sticks at 26 mins.
  • #39014
    Went out to this morning, didn’t have my laptop with me so couldn’t run the diagnostics from the TDS disc.
    I ran the machine through fill, wash, heat, drain & spin without any problems.
    She says it sticks at 26 minutes with the machine totally dead.
    Going to return to run diagnostics, any pointers before I do?
    jim.
    #260939
    maltheviking
    Re: Zanussi WJD1257W. Sticks at 26 mins.
    Hi Jim
    I know you said you checked the heater, 🙂
    I had one of these turned out to be a wire hanging of the heater, worth a second look 😉
    #260940
    Will give it a closer look when I return. 8)
    cab
    auto syphoning?
    #260942
    Doubt it, she says she has to drain the water from the filter when it stops. She is getting on a bit and did seem a little confused though, a bit like me really. 😀
    Jim,
    I have had so problems from pump which could be stuck or couldn’t get rotating because warming…
    Perhaps it can run when you run rinse program but when became warm from washing water it will fail to start turning…
    #260944
    A worthy suggestion Adrian, I will also give that a look at although to be truthful, the pump did run very quite and smooth, most failing pumps often sound noisy.
    Can you tell me what type of electronic (PCB) is there? because in EWM2000 case – perhaps it will help if you set again configuration code
    but in all other cases (EWM1000/plus; EWM2000EVO…) -it can be programms fault and memory must be reprogramm it…. I have done lot of them also…
    #260946
    iadom wrote:A worthy suggestion Adrian, I will also give that a look at although to be truthful, the pump did run very quite and smooth, most failing pumps often sound noisy.
    ive had some of these pumps that have not been noisy, and still stick !
    so one to keep an eye on? 😯
    regards
    canufixit
    #260947
    Customer has just told me that since my visit it has now done four washes perfectly. I did suspect all along that there was nothing wrong with the machine, she did seem rather vague. :rolls:
    Will have to see if she phones back again. 😉
    At least did you’ve charge them for that visit?
    #260949
    Sadly no, however it was my fault that I did not have my laptop with me at the time so was unable to run the diagnostics, it been a very hectic week, just back from two weeks holiday. I’m still getting back into my routine. 😉
