My zanussi wjd1257w washer/dryer won’t drain.
It’s worked fine for 5 years, so it’s not the way it’s been installed. As soon as the cycle reaches the first drain it just beeps E20 (problem with filter / drainage) and I have to drain it by removing the filter and letting it flow out of the front. It will only complete the cycle if I do this each time it needs to drain. However, it doesnt actually clean the clothes – they come out stinking of manky water! 🙁
The filter is clean, the pipe from the back is not blocked and neither is the the pipe it flows into. Is it likely to be the pump? What else could it be? I don’t want to spend money on a pump to find out that it isn’t that at all!
Please help!
